Visually Guided Object Grasping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics and Automation Année : 1998
In this paper, we present a visual servoing approach to the problem of object grasping and more generally, to the problem of aligning an end-effector with an object. First we extend the method proposed by Espiau, Chaumette, and Rives (see reference [1]) to the case of a camera which is not mounted onto the robot being controlled and we stress the importance of the real-time estimation of the image Jacobian. Second, we show how to represent a grasp or more generally, an alignment between two solids in three-dimensional (3-D) projective space using an uncalibrated stereo rig. Such a 3-D projective representation is view-invariant in the sense that it can be easily mapped into an image set-point without any knowledge about the camera parameters. Third, we perform an analysis of the performances of the visual servoing algorithm and of the grasping precision that can be expected from this type of approach.
HoraudDornaikaEspiau-RA98-trans.pdf (315.58 Ko) Télécharger le fichier
inria-00590088 , version 1 (03-05-2011)
Radu Horaud, Fadi Dornaika, Bernard Espiau. Visually Guided Object Grasping. IEEE Transactions on Robotics and Automation, 1998, 14 (4), pp.525--532. ⟨10.1109/70.704214⟩. ⟨inria-00590088⟩
124 Consultations
379 Téléchargements
