Articulated Motion Capture from 3-D Points and Normals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper we address the problem of tracking the motion of articulated objects from their 2-D silhouettes gathered with several cameras. The vast majority of existing approaches relies on a single camera or on stereo. We describe a new method which requires at least two cameras. The method relies on (i) building 3-D observations (points and normals) from image silhouettes and on (ii) fitting an articulated object model to these observations by minimizing their discrepancies. The objective function sums up these discrepancies while it takes into account both the scaled algebraic distance from data points to the model surface and the offset in orientation between observed normals and model normals. The combination of a feed-forward reconstruction technique with a robust model-tracking method results in a reliable and efficient method for articulated motion capture.
bmvc05-85final.pdf (294.86 Ko) Télécharger le fichier
1_Image1.tif (1.32 Mo) Télécharger le fichier
2_cam4_s59.tif (3.33 Ko) Télécharger le fichier
3_cam4_59.tif (34.47 Ko) Télécharger le fichier
4_cam4_59s.tif (1.3 Mo) Télécharger le fichier
Ben_Cam0.avi (1.36 Mo) Télécharger le fichier
articulated_motion.avi (3.85 Mo) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00590195 , version 1 (03-05-2011)
  • HAL Id : inria-00590195 , version 1
Matti Niskanen, Edmond Boyer, Radu Horaud. Articulated Motion Capture from 3-D Points and Normals. British Machine Vision Conference (BMVC '05), Sep 2005, Oxford, United Kingdom. pp.439--448. ⟨inria-00590195⟩
112 Consultations
127 Téléchargements
