Automatic Discovery of Action Taxonomies from Multiple Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present a new method for segmenting actions into primitives and classifying them into a hierarchy of action classes. Our scheme learns action classes in an unsupervised manner using examples recorded by multiple cameras. Segmentation and clustering of action classes is based on a recently proposed motion descriptor which can be extracted ef ciently from reconstructed volume sequences. Because our representation is independent of viewpoint, it results in segmentation and classi cation methods which are surprisingly ef cient and robust. Our new method can be used as the rst step in a semi-supervised action recognition system that will automatically break down training examples of people performing sequences of actions into primitive actions that can be discriminatingly classi ed and assembled into high-level recognizers.
1137_weinland_d.pdf (886.17 Ko) Télécharger le fichier
DoAT_low.avi (13.12 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00590216 , version 1 (03-05-2011)
Daniel Weinland, Rémi Ronfard, Edmond Boyer. Automatic Discovery of Action Taxonomies from Multiple Views. IEEE Conference on Computer Vision and Pattern Recognition (CVPR '06), Jun 2006, New York, United States. pp.1639--1645, ⟨10.1109/CVPR.2006.65⟩. ⟨inria-00590216⟩
296 Consultations
245 Téléchargements
