Introduction to the Multifractal Analysis of Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1998
After a brief review of some classical approaches in image segmentation, the basics of multifractal theory and its application to image analysis are presented. Practical methods for multifractal spectrum estimation are discussed and some experimental results are given.
Introduction_to_the_Multifractal_Analysis_of_Images.pdf (17.6 Mo) Télécharger le fichier
inria-00592425 , version 1 (12-05-2011)
  • HAL Id : inria-00592425 , version 1
Jacques Lévy Véhel. Introduction to the Multifractal Analysis of Images. Yuval Fisher. Fractal Image Encoding and Analysis, 159, Springer, pp.299-341, 1998, 3-540-63196-8. ⟨inria-00592425⟩
Collections
INRIA INRIA2
410 Consultations
261 Téléchargements
