A new variational method for preserving point-like and curve-like singularities in 2D images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Daniele Graziani
  • Fonction : Auteur
  • PersonId : 859871
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 841269
We propose a new variational method to restore point-like and curve-like singularities in 2-D images. As points and open curves are fine structures, they are difficult to restore by means of first order derivative operators computed in the noisy image. In this paper we propose to use the Laplacian operator of the observed intensity, since it becomes singular at points and curves. Then we propose to restore these singularities by introducing suitable regularization involving the l-1-norm of the Laplacian operator. Results are shown on synthetic an real data.
Grazianiicasp.pdf (175.45 Ko) Télécharger le fichier
inria-00592603 , version 1 (13-05-2011)
  • HAL Id : inria-00592603 , version 1
Daniele Graziani, Laure Blanc-Féraud, Gilles Aubert. A new variational method for preserving point-like and curve-like singularities in 2D images. International Conference on Acoustics, Speech and Signal Processing, 2011, Prague, Czech Republic. ⟨inria-00592603⟩
115 Consultations
174 Téléchargements
