SCA Platform Specifications - Version 2.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The SCOrWare project aims at building an open source implementation of the Service Component Architecture (SCA) specifications. This implementation is composed of 1) a runtime platform for deploying, executing, and managing SCAbased applications, 2) a set of development tools for modeling, designing, and implementing SCA-based applications, and 3) a set of demonstrators. This document contains the specifications of the SCOrWare runtime platform. Section 1.1 lists the parts of SCA specifications supported by the SCOrWare platform. Section 1.2 gives an overview of the SCOrWare platform, and a summary of next chapters of this document. Section 1.3 lists the main update from the version 1 to the version 2 of this document
SCOrWare-L1-Specifications-V2-0-20090327.pdf (3.03 Mo) Télécharger le fichier
inria-00595502 , version 1 (24-05-2011)
  • HAL Id : inria-00595502 , version 1
Damien Fournier, Philippe Merle, Gaël Blondelle, Lionel Seinturier, Nicolas Dolet, et al.. SCA Platform Specifications - Version 2.0. [Research Report] INRIA. 2009. ⟨inria-00595502⟩
649 Consultations
453 Téléchargements
