s'authentifier
version française rss feed
inria-00598712, version 1
Multi-Agent Electro-Location and the Among Constraint
Gilles Chabert (Auteur à contacter de préférence) a12, Frédéric Boyer () a3, Sophie Demassey () a14
N° RR-7640 (2011)
Résumé : In this paper, we give a new approach for the localization of several autonomous fish robots equipped with the electric sense. The approach is based on interval arithmetic and constraint programming. It introduces a generalization of the Among constraint which was used so far in the different context of resource allocation in logistics. We prove that the bound consistency for a conjunction of Among constraints with interval domains is NP-complete in the vector case and polynomial in the one-dimensional case. Although it was designed for electric fish robots, this work is not restricted to this type of systems. The approach can be easily extended to other multi-agent systems with low-range sensing.
  • Domaine : Informatique/Intelligence artificielle
    Informatique/Robotique
    Informatique/Mathématique discrète
    Informatique/Système multi-agents
    Informatique/Complexité
  • Référence interne : RR-7640
  • inria-00598712, version 1
  • oai:hal.inria.fr:inria-00598712
  • Contributeur :
  • Soumis le : Mardi 7 Juin 2011, 13:18:49
  • Dernière modification le : Vendredi 17 Juin 2011, 16:47:55
tous les articles de la base du CCSd...
