Control Architecture for Cooperative Mobile Robots using Multi-Agent based Coordination Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is about a Multi-Agent based solution to control and coordinate team-working mobile robots moving in unstructured environments. Two main contributions are considered in our approach. The rst contribution of this paper is about the Multi-Agents System to Control and Coordinate teAmworking Robots (MAS2CAR) architecture, a new architecture to control a group of coordinated autonomous robots in unstructured environments. MAS2CAR covers three main layers: (i) the Physical Layer (ii) the Control Layer and (iii) the Coordination Layer. The second contribution of this paper is about the multi-agent system (MAS) organisational models aiming to solve the key cooperation issues in the coordination layer, the software components designed based on Utopia a MAS framework which automatically build software agents, thanks to a multi-agent based organisational model called MoiseInst . We provide simulation results that exhibit robotics cooperative behavior related to our scenario, such as multi-robots navigation in presence of obstacles (including trajectory planning, and reactive aspects) via a hybrid control.
Mouad-control-archi.PDF (416.77 Ko) Télécharger le fichier
inria-00599602 , version 1 (10-06-2011)
  • HAL Id : inria-00599602 , version 1
Mehdi Mouad, Lounis Adouane, Pierre Schmitt, Djamel Khadraoui, Philippe Martinet. Control Architecture for Cooperative Mobile Robots using Multi-Agent based Coordination Approach. 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 15 p. ⟨inria-00599602⟩
223 Consultations
392 Téléchargements
