Hardware-in-the-loop test-bed of an Unmanned Aerial Vehicle using Orccad - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
During the development of control systems, hardware-in-the-loop (HIL) takes place between design level simulations and costly experiments with the real plant. In this particular experiment the controller is designed under Orccad, as a set of multi-rate tasks, allowing for testing weakly hard scheduling schemes. The controller is embedded on a microcontroller synchronized via a CAN bus to a mini-drone simulator. Observing the simulation traces helps to tune the control design, and avoid crashing down the real system in early testing.
Simon-hardware.PDF (658.58 Ko) Télécharger le fichier
inria-00599685 , version 1 (10-06-2011)
  • HAL Id : inria-00599685 , version 1
Daniel Simon. Hardware-in-the-loop test-bed of an Unmanned Aerial Vehicle using Orccad. CAR 2011 - 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 14 p. ⟨inria-00599685⟩
374 Consultations
1234 Téléchargements
