Proxy-Guided Texture Synthesis for Rendering Natural Scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Landscapes and other natural scenes are easy to photograph but difficult to model and render. We present a proxy-guided pipeline which allows for simple 3D proxy geometry to be rendered with the rich visual detail found in a suitably pre-annotated example image. This greatly simplifies the geometric modeling and texture mapping of such scenes. Our method renders at near-interactive rates and is designed by carefully adapting guidancebased texture synthesis to our goals. A guidance-map synthesis step is used to obtain silhouettes and borders that have the same rich detail as the source photo, using a Chamfer distance metric as a principled way of dealing with discrete texture labels. We adapt an efficient parallel approach to the challenging guided synthesis step we require, providing a fast and scalable solution. We provide a solution for local temporal coherence, by introducing a reprojection algorithm, which reuses earlier synthesis results when feasible, as measured by a distortion metric. Our method allows for the consistent integration of standard CG elements with the texture-synthesized elements. We demonstrate near-interactive camera motion and landscape editing on a number of examples.
Proxy.pdf (18.07 Mo) Télécharger le fichier
ProxyAd.pdf (8.62 Mo) Télécharger le fichier
VideoProxy.mp4 (78.67 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
inria-00607173 , version 1 (08-07-2011)
Nicolas Bonneel, Michiel van de Panne, Sylvain Lefebvre, George Drettakis. Proxy-Guided Texture Synthesis for Rendering Natural Scenes. Vision Modeling and Visualization Workshop (VMV 2010), Nov 2010, Siegen, Germany. pp.87--95, ⟨10.2312/PE/VMV/VMV10/087-095⟩. ⟨inria-00607173⟩
189 Consultations
82 Téléchargements
