The Dual Code of Points and t-Spaces in the Projective Space
The most important results on C1/t (n; q), the dual code of points and t-spaces in PG(n, q) are presented. We focus on the minimum distance and on the small weight codewords. In the third section, a recent result about the classi cation of the small weight codewords in C 1/n-1(n, q), q even, is given.
Cryptographie et sécurité [cs.CR]
