On CCZ-equivalence of Addition mod 2n - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that addition mod 2n is CCZ-equivalent to a quadratic vectorial Boolean function. We use this to reduce the solution of systems di erential equations of addition to the solution of a system of linear equations and to derive a fully explicit formula for the correlation coe cients, which leads to new results about the Walsh transform of addition mod 2n . The results have applications in the cryptanalysis of cyptographic primitives which use addition mod 2n .
113.pdf (145.22 Ko) Télécharger le fichier
inria-00607747 , version 1 (11-07-2011)
  • HAL Id : inria-00607747 , version 1
Ernst Schulte-Geers. On CCZ-equivalence of Addition mod 2n. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.131-142. ⟨inria-00607747⟩
Collections
WCC2011 TDS-MACS
123 Consultations
1103 Téléchargements
