A variant of the McEliece cryptosystem with increased public key security - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new variant of the McEliece cryptosystem which ensures that the code used as the public key is not permutation-equivalent to the secret code. This allows to increase the security of the public key, and to reconsider possible adoption of classical families of codes, like Reed-Solomon codes. A reduction in the key size or, equivalently, an increased level of security against nformation set decoding are the main advantages of the modi ed cryptosystem. As a drawback, the domain of intentional error vectors must be restricted, but we show that this has no signi cant impact on the security level.
69.pdf (102.51 Ko) Télécharger le fichier
inria-00607772 , version 1 (11-07-2011)
  • HAL Id : inria-00607772 , version 1
Marco Baldi, Marco Bianchi, Franco Chiaraluce, Joachim Rosenthal, Davide Schipani. A variant of the McEliece cryptosystem with increased public key security. WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.173-182. ⟨inria-00607772⟩
Collections
WCC2011 TDS-MACS
217 Consultations
399 Téléchargements
