Spatial Fisher Vectors for Image Categorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
We introduce an extension of bag-of-words image representations to encode spatial layout. Using the Fisher kernel framework we derive a representation that encodes the spatial mean and the variance of image regions associated with visual words. We extend this representation by using a Gaussian mixture model to encode spatial layout, and show that this model is related to a soft-assign version of the spatial pyramid representation. We also combine our representation of spatial layout with the use of Fisher kernels to encode the appearance of local features. Through an extensive experimental evaluation, we show that our representation yields state-of-the-art image categorization results, while being more compact than spatial pyramid representations. In particular, using Fisher kernels to encode both appearance and spatial layout results in an image representation that is computationally efficient, compact, and yields excellent performance while using linear classifiers.
RR-7680.pdf (276.68 Ko) Télécharger le fichier
Format : Figure, Image
inria-00613572 , version 1 (04-08-2011)
  • HAL Id : inria-00613572 , version 1
Josip Krapac, Jakob Verbeek, Frédéric Jurie. Spatial Fisher Vectors for Image Categorization. [Research Report] RR-7680, INRIA. 2011. ⟨inria-00613572⟩
595 Consultations
1082 Téléchargements
