EasyText: an Operational NLG System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces EasyText, a fully operational NLG System. This application processes numerical data (in tables) in order to generate specific analytical comments of these tables. We start by describing the context of this particular NLG application (communicative goal, user profiles, etc.). We then shortly present the theoretical background which underlies EasyText, before describing its implementation and realization.
easyVanessaFredo.pdf (259.62 Ko) Télécharger le fichier
inria-00614760 , version 1 (16-08-2011)
  • HAL Id : inria-00614760 , version 1
Laurence Danlos, Frédéric Meunier, Vanessa Combet. EasyText: an Operational NLG System. ENLG 2011 - 13th European Workshop on Natural Language Generation, Sep 2011, Nancy, France. ⟨inria-00614760⟩
199 Consultations
209 Téléchargements
