Discourse Relations and Propositional Attitudes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a procedure how discourse should be processed when segments are not asserted by the writer but attributed by her to other sources.
Linguistique
CID-final-Owen.pdf (119.97 Ko) Télécharger le fichier
inria-00614763 , version 1 (16-08-2011)
  • HAL Id : inria-00614763 , version 1
Laurence Danlos, Owen Rambow. Discourse Relations and Propositional Attitudes. CID 2011 - Fourth International workshop on Constraints in Discourse, Sep 2011, Agay-Roches Rouges, France. ⟨inria-00614763⟩
165 Consultations
217 Téléchargements
