Coupling an annotated corpus and a lexicon for state-of-the-art POS tagging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Language Resources and Evaluation Année : 2012
This paper investigates how to best couple hand-annotated data with information extracted from an external lexical resource to improve POS tagging performance. Focusing on French tagging, we introduce a maximum entropy conditional sequence tagging system that is enriched with information extracted from a morphological resource. This system gives a 97.7% accuracy on the French Treebank, an error reduction of 23% (28% on unknown words) over the same tagger without lexical information. We also conduct experiments on datasets and lexicons of varying sizes in order to assess the best trade-off between annotating data vs. developing a lexicon. We find that the use of a lexicon improves the quality of the tagger at any stage of development of either resource, and that for fixed performance levels the availability of the full lexicon consistently reduces the need for supervised data by at least one half.
lre12-denis-sagot.pdf (132.29 Ko) Télécharger le fichier
inria-00614819 , version 1 (20-07-2012)
Pascal Denis, Benoît Sagot. Coupling an annotated corpus and a lexicon for state-of-the-art POS tagging. Language Resources and Evaluation, 2012, 46 (4), pp.721-736. ⟨10.1007/s10579-012-9193-0⟩. ⟨inria-00614819⟩
410 Consultations
891 Téléchargements
