Medical Image Registration using Geometric Hashing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Computational Science and Engineering Année : 1997
To carefully compare pictures of the same thing taken from different views, the images must first be registered, or aligned so as to best superimpose them. Results show that two geometric hashing methods, based respectively on curves and characteristic features, can be used to compute 3D transformations that automatically register medical images of the same patient in a practical, fast, accurate, and reliable manner.
Gueziec.Pennec.Ayache.CSE.GH.pdf (505.06 Ko) Télécharger le fichier
Gueziec.Pennec.Ayache.CSE.GH.a4.pdf (488.54 Ko) Télécharger le fichier
inria-00615068 , version 1 (17-08-2011)
André Guéziec, Xavier Pennec, Nicholas Ayache. Medical Image Registration using Geometric Hashing. IEEE Computational Science and Engineering, 1997, 4 (4), pp.29-41. ⟨10.1109/99.641607⟩. ⟨inria-00615068⟩
171 Consultations
545 Téléchargements
