Trinocular Stereovision for Robotics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 1991
An approach to building a three-dimensional description of the environment of a robot using three cameras is presented. The main advantages of trinocular versus binocular stereo are simplicity, reliability, and accuracy. It is believed that these advantages make trinocular stereo vision of practical use for many robotics applications. The technique has been successfully applied to several indoor and industrial scenes. Experimental results are presented and discussed
AyachePAMI1991.pdf (1.21 Mo) Télécharger le fichier
inria-00615530 , version 1 (19-08-2011)
  • HAL Id : inria-00615530 , version 1
Nicholas Ayache, Francis Lustman. Trinocular Stereovision for Robotics. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1991, 13 (1). ⟨inria-00615530⟩
457 Consultations
539 Téléchargements
