Multimodal Prior Appearance Models based on Regional Clustering of Intensity Profiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Model-based image segmentation requires prior information about the appearance of a structure in the image. Instead of relying on Principal Component Analysis such as in Statistical Appearance Models, we propose a method based on a regional clustering of intensity profiles that does not rely on an accurate pointwise registration. Our method is built upon the Expectation-Maximization algorithm with regularized covariance matrices and includes spatial regularization. The number of appearance regions is determined by a novel model order selection criterion. The prior is described on a reference mesh where each vertex has a probability to belong to several intensity profile classes.
multimodal_prior_appearance_models_based_on_regional_clustering_of_intensity_profiles.pdf (500.74 Ko) Télécharger le fichier
inria-00616132 , version 1 (08-07-2013)
François Chung, Hervé Delingette. Multimodal Prior Appearance Models based on Regional Clustering of Intensity Profiles. Medical Image Computing and Computer-Assisted Intervention (MICCAI'09), 2009, London, United Kingdom. pp.1051--1058, ⟨10.1007/978-3-642-04271-3_127⟩. ⟨inria-00616132⟩
94 Consultations
93 Téléchargements
