Estimation of Reaction, Diffusion and Restitution Parameters for a 3D Myocardial Model Using Optical Mapping and MRI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Personalisation, i.e. parameter estimation of a cardiac ElectroPhysiology (EP) model is needed to build patient-specific models, which could then be used to understand the true complex dynamics involved in patient's pathology. In this paper, we present a personalisation method for a simplified ionic 3D EP model, the Mitchell-Schaeffer model. The personalisation is performed by optimising the 3D model parameters, which represent the tissue conductivity, Action Potential Duration (APD) and restitution for APD and conduction velocity, using only 2D epicardial surface data obtained ex-vivo from optical imaging of large porcine healthy hearts. We are also able to estimate all of the model parameters, thus resulting in a total heart-specific 3D EP model. Finally, we also test the sensitivity of the described personalisation results with respect to different pacing locations.
relan_STACOM_MICCAI_2010.pdf (659.41 Ko) Télécharger le fichier
inria-00616151 , version 1 (08-07-2013)
Jatin Relan, Mihaela Pop, Hervé Delingette, Graham Wright, Nicholas Ayache, et al.. Estimation of Reaction, Diffusion and Restitution Parameters for a 3D Myocardial Model Using Optical Mapping and MRI. MICCAI Workshop on Statistical Atlases and Computational Models of the Heart: Mapping Structure and Function (STACOM) and a Cardiac Electrophysiological Simulation Challenge (CESC'10), 2010, Beijing, China. pp.270-280, ⟨10.1007/978-3-642-15835-3_28⟩. ⟨inria-00616151⟩
153 Consultations
154 Téléchargements
