Statistical Computing on Non-Linear Spaces for Computational Anatomy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Computational anatomy is an emerging discipline that aims at analyzing and modeling the individual anatomy of organs and their biological variability across a population. However, understanding and modeling the shape of organs is made difficult by the absence of physical models for comparing different subjects, the complexity of shapes, and the high number of degrees of freedom implied. Moreover, the geometric nature of the anatomical features usually extracted raises the need for statistics on objects like curves, surfaces and deformations that do not belong to standard Euclidean spaces. We explain in this chapter how the Riemannian structure can provide a powerful framework to build generic statistical computing tools. We show that few computational tools derive for each Riemannian metric can be used in practice as the basic atoms to build more complex generic algorithms such as interpolation, filtering and anisotropic diffusion on fields of geometric features. This computational framework is illustrated with the analysis of the shape of the scoliotic spine and the modeling of the brain variability from sulcal lines where the results suggest new anatomical findings.
ComputationalAnatomy.pdf (614.78 Ko) Télécharger le fichier
inria-00616201 , version 1 (19-07-2013)
Xavier Pennec, Pierre Fillard. Statistical Computing on Non-Linear Spaces for Computational Anatomy. Paragios, Nikos and Duncan, Jim and Ayache, Nicholas. Handbook of Biomedical Imaging: Methodologies and Clinical Research, Springer, pp.147-168, 2015, 978-0-387-09748-0. ⟨10.1007/978-0-387-09749-7_8⟩. ⟨inria-00616201⟩
377 Consultations
463 Téléchargements
