s'authentifier
version française rss feed
inria-00617965, version 3
Local Component Analysis
Nicolas Le Roux () 12, Francis Bach () 12
Résumé : Kernel density estimation, a.k.a. Parzen windows, is a popular density estimation method, which can be used for outlier detection or clustering. With multivariate data, its performance is heavily reliant on the metric used within the kernel. Most earlier work has focused on learning only the bandwidth of the kernel (i.e., a scalar multiplicative factor). In this paper, we propose to learn a full Euclidean metric through an expectation-minimization (EM) procedure, which can be seen as an unsupervised counterpart to neighbourhood component analysis (NCA). In order to avoid overfitting with a fully nonparametric density estimator in high dimensions, we also consider a semi-parametric Gaussian-Parzen density model, where some of the variables are modelled through a jointly Gaussian density, while others are modelled through Parzen windows. For these two models, EM leads to simple closed-form updates based on matrix inversions and eigenvalue decompositions. We show empirically that our method leads to density estimators with higher test-likelihoods than natural competing methods, and that the metrics may be used within most unsupervised learning techniques that rely on such metrics, such as spectral clustering or manifold learning methods. Finally, we present a stochastic approximation scheme which allows for the use of this method in a large-scale setting.
  • inria-00617965, version 3
  • oai:hal.inria.fr:inria-00617965
  • Contributeur :
  • Soumis le : Mardi 27 Septembre 2011, 17:09:29
  • Dernière modification le : Mercredi 28 Septembre 2011, 06:16:11
tous les articles de la base du CCSd...
