s'authentifier
version française rss feed
inria-00618656, version 2
Well Balanced Designs for Data Placement
Jean-Claude Bermond () 1, Alain Jean-Marie () 23, Dorian Mazauric () 12, Joseph Yu () 1
N° RR-7725 (2011)
Résumé : The problem we consider in this article is motivated by data placement in particular data replication in video on demand systems. We are given a set V of n servers and b files (data, documents). Each file is replicated on exactly k servers. The problem is to determine the placement that minimizes the variance of the number of unavailable datas. To do that, we consider the problem of determining well balanced designs, a difficult problem because it contains the problem of the existence of Steiner systems.
  • Domaine : Informatique/Algorithme et structure de données
  • Référence interne : RR-7725
  • Versions disponibles :  v1 (02-09-2011) v2 (05-09-2011)
  • inria-00618656, version 2
  • oai:hal.inria.fr:inria-00618656
  • Contributeur :
  • Soumis le : Lundi 5 Septembre 2011, 13:18:51
  • Dernière modification le : Lundi 5 Septembre 2011, 13:35:48
tous les articles de la base du CCSd...
