Computationally Efficient MR-FDPF Method for Multifrequency Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this report, we propose a modification of the multi-resolution frequency domain ParFlow (MR-FDPF) method that allows simulating radio propagation channels in a frequency range. The performance of the proposed MR-FDPF implementation has been analyzed based on different realistic propagation scenarios.
RR-7726.pdf (2.36 Mo) Télécharger le fichier
inria-00621315 , version 1 (10-09-2011)
  • HAL Id : inria-00621315 , version 1
Dmitry Umansky, Jean-Marie Gorce, Meiling Luo, Guillaume de La Roche, Guillaume Villemaud. Computationally Efficient MR-FDPF Method for Multifrequency Simulations. [Research Report] RR-7726, INRIA. 2011. ⟨inria-00621315⟩
130 Consultations
88 Téléchargements
