Stereoscopic Image Inpainting using scene geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose an algorithm for stereoscopic image inpainting, given the inpainting mask in both images. We also assume that depth map is known in one of the images of the stereo pair, taken as reference. This image is clustered in homogeneous color regions using a mean-shift procedure. In each clustered region, depths are fitted by planes and then extended into the mask. Then we inpaint the visible parts of each extended region using a modified exemplar-based inpainting algorithm. Finally, we extend the algorithm to stereoscopic image inpainting. We display some experiments showing the performance of the proposed algorithm.
inp.pdf (4.05 Mo) Télécharger le fichier
inria-00622591 , version 1 (20-09-2011)
Alexandre Hervieu, Nicolas Papadakis, Aurélie Bugeau, Pau Gargallo I Piracés, Vicent Caselles. Stereoscopic Image Inpainting using scene geometry. IEEE International Conference on Multimedia and Expo (ICME'11), Jul 2011, Barcelona, Spain. pp.1-6, ⟨10.1109/ICME.2011.6011901⟩. ⟨inria-00622591⟩
303 Consultations
791 Téléchargements
