The SANTE Tool: Value Analysis, Program Slicing and Test Generation for C Program Debugging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This short paper presents a prototype tool called SANTE (Static ANalysis and TEsting) implementing an original method combining value analysis, program slicing and structural test generation for verification of C programs. First, value analysis is called to generate alarms when it can not guarantee the absence of errors. Then the program is reduced by program slicing. Alarm-guided test generation is then used to analyze the simplified program(s) in order to confirm or reject alarms.
CKGJ11.pdf (64.36 Ko) Télécharger le fichier
inria-00622904 , version 1 (13-09-2011)
Omar Chebaro, Nikolai Kosmatov, Alain Giorgetti, Jacques Julliand. The SANTE Tool: Value Analysis, Program Slicing and Test Generation for C Program Debugging. 5th International Conference on Tests & Proofs, Jun 2011, Zurich, Switzerland. pp.78-83, ⟨10.1007/978-3-642-21768-5⟩. ⟨inria-00622904⟩
239 Consultations
343 Téléchargements
