Semiconcavity of the Minimum Time Function for Differential Inclusions
In this paper we consider the Minimum Time Problem with dynamics given by a differential inclusion. We prove that the minimum time function is semiconcave under suitable hypotheses on the multifunction F.
Optimisation et contrôle [math.OC]
