Maximum Likelihood BSC Parameter Estimation for the Slepian-Wolf Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Letters Année : 2011
In the context of Distributed Source Coding, we propose a low complexity algorithm for the estimation of the cross-over probability p of the Binary Symmetric Channel (BSC) modeling the correlation between two binary sources. The coding is done with linear block codes. We propose a novel method to estimate p prior to decoding and show that it is the Maximum Likelihood estimator of p with respect to the syndromes of the correlated sources. The method can be utilized for the parameter estimation for channel coding of binary sources over the BSC.
11Comm_Letter_TRG.pdf (446.91 Ko) Télécharger le fichier
inria-00628996 , version 1 (04-10-2011)
inria-00628996 , version 2 (18-10-2011)
Velotiaray Toto-Zarasoa, Aline Roumy, Christine Guillemot. Maximum Likelihood BSC Parameter Estimation for the Slepian-Wolf Problem. IEEE Communications Letters, 2011, 15 (2), ⟨10.1109/LCOMM.2011.122810.102182⟩. ⟨inria-00628996v2⟩
260 Consultations
316 Téléchargements
