A guided approach for automatic segmentation and modeling of the vocal tract in MRI images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An automatic approach for segmenting tongue contours in physical correspondences is described in this paper. The goal is to be able to segment large MRI database and to automatically produce vocal tract models from these data. We extend the guided method presented in \cite{peng2010} in order to obtain physically corresponding curves and provide in-deep evaluation of the method.
Mots clés
bergerEusipcoFinal.pdf (1.13 Mo) Télécharger le fichier
inria-00630642 , version 1 (10-10-2011)
  • HAL Id : inria-00630642 , version 1
Abdulkadir Eryildirim, Marie-Odile Berger. A guided approach for automatic segmentation and modeling of the vocal tract in MRI images. European Signal Processing Conference (EUSIPCO‐2011), Aug 2011, Barcelone, Spain. ⟨inria-00630642⟩
131 Consultations
216 Téléchargements
