Distributed monitoring of concurrent and asynchronous systems. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Event Dynamic Systems Année : 2005
In this paper we study the diagnosis of distributed asynchronous systems with concurrency. Diagnosis is performed by a peer-to-peer distributed architecture of supervisors. Our approach relies on Petri net unfoldings and event structures, as means to manipulate trajectories of systems with concurrency. This article is an extended version of the paper with same title, which appeared as a plenary address in the Proceedings of CONCUR'2003.
FBJH-deds05.pdf (796.04 Ko) Télécharger le fichier
inria-00638219 , version 1 (04-11-2011)
Eric Fabre, Albert Benveniste, Stefan Haar, Claude Jard. Distributed monitoring of concurrent and asynchronous systems.. Discrete Event Dynamic Systems, 2005, 15 (1), pp.33-84. ⟨10.1007/s10626-005-5238-5⟩. ⟨inria-00638219⟩
118 Consultations
400 Téléchargements
