Enabling Collaboration between Heterogeneous 3D Viewers through a PAC-C3D Modeling of the Shared Virtual Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose to illustrate how the PAC-C3D software model makes it possible to share networked 3D Virtual Environments (VE) between heterogeneous 3D viewers written in Java3D and jReality.
demoIcat2011.pdf (232.72 Ko) Télécharger le fichier
inria-00638638 , version 1 (06-04-2014)
  • HAL Id : inria-00638638 , version 1
Thierry Duval, Cédric Fleury. Enabling Collaboration between Heterogeneous 3D Viewers through a PAC-C3D Modeling of the Shared Virtual Environment. ICAT 2011 (The 21st International Conference on Artificial Reality and Telexistence), VRSJ, Nov 2011, Osaka, Japan. pp.156. ⟨inria-00638638⟩
153 Consultations
75 Téléchargements
