GPU & CPU implementation of Young - Van Vliet's Recursive Gaussian Smoothing Filter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Insight Journal Année : 2013
This document describes an implementation for GPU and CPU of Young and Van Vliet's recursive Gaussian smoothing as an external module for the Insight Toolkit ITK, version 4.* www.itk.org. In the absence of an OpenCL-capable platform, the code will run the CPU implementation as an alternative to the existing Deriche recursive Gaussian smoothing filter in ITK.
IJ_896_3_InsightJournal_YVV.pdf (1.34 Mo) Télécharger le fichier
inserm-00855958 , version 1 (30-08-2013)
  • HAL Id : inserm-00855958 , version 1
Irina Vidal-Migallón, Olivier Commowick, Xavier Pennec, Julien Dauguet, Tom Vercauteren. GPU & CPU implementation of Young - Van Vliet's Recursive Gaussian Smoothing Filter. Insight Journal, 2013, pp.16. ⟨inserm-00855958⟩
695 Consultations
2451 Téléchargements
