ABS: The Anti Bouncing Model for Usage Data Streams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Usage data mining is an important research area with applications in various fields. However, usage data is usually considered streaming, due to its high volumes and rates. Because of these characteristics, we only have access, at any point in time, to a small fraction of the stream. When the data is observed through such a limited window, it is challenging to give a reliable description of the recent usage data. We study the important consequences of these constraints, through the "bounce rate" problem and the clustering of usage data streams. Then, we propose the ABS (Anti-Bouncing Stream) model which combines the advantages of previous models but discards their drawbacks. First, under the same resource constraints as existing models in the literature, ABS can better model the recent data. Second, owing to its simple but effective management approach, the data in ABS is available at any time for analysis. We demonstrate its superiority through a theoretical study and experiments on two real-world data sets.
Fichier non déposé
lirmm-00653732 , version 1 (20-12-2011)
Chongsheng Zhang, Florent Masseglia, Yves Lechevallier. ABS: The Anti Bouncing Model for Usage Data Streams. ICDM 2010 - 10th IEEE International Conference on Data Mining, Dec 2010, Sydney, NSW, Australia. pp.1169-1174, ⟨10.1109/ICDM.2010.91⟩. ⟨lirmm-00653732⟩
272 Consultations
0 Téléchargements
