Read indexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EMBnet.journal Année : 2011
Read indexing
The question of read indexing remains broadly unexplored. However, the increase in sequence throughput urges for new algorithmic solutions to query large read collections efficiently. We pro- pose a solution, named Gk arrays, to index large collections of reads, an algorithm to build the structure, and procedures to query it. Once constructed, the index structure is kept in main memory and is repeatedly accessed to answer various types of queries. We compare our data structure to other possible solutions to investigate its scalability and computational efficiency. Gk arrays are im- plemented in a general purpose library, which may prove useful for assembly purposes, for evaluating the expression level in RNA-seq, and others high throughput sequencing applications.
289-2729-1-PB.pdf (177.97 Ko) Télécharger le fichier
lirmm-00757983 , version 1 (27-11-2012)
Nicolas Philippe, Mikael Salson, Thérèse Commes, Thierry Lecroq, Martine Léonard, et al.. Read indexing. EMBnet.journal, 2011, 17 (Supplement B), pp.1. ⟨10.14806/ej.17.B.289⟩. ⟨lirmm-00757983⟩
495 Consultations
250 Téléchargements
