YAM++ - Results for OAEI 2012 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The YAM++ system is a self configuration, flexible and extensible ontology matching system. YAM++ takes advantages of many techniques coming from different fields such as machine learning, information retrieval, graph matching, etc. in order to enhance the matching quality. In this paper, we briefly present the YAM++ approach and its results on OAEI 2012 campaign.
YAM_2012.pdf (169.62 Ko) Télécharger le fichier
lirmm-00758720 , version 1 (29-11-2012)
  • HAL Id : lirmm-00758720 , version 1
Duy Hoa Ngo, Zohra Bellahsene. YAM++ - Results for OAEI 2012. International Semantic Web Conference, Nov 2012, United States. ⟨lirmm-00758720⟩
548 Consultations
542 Téléchargements
