Soundness and Completeness of Relational Concept Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Relational Concept Analysis (RCA) is an extension of Formal Concept Analysis (FCA) to the processing of relational datasets, i.e., made of (objects X properties) contexts and (objects X objects) relations. RCA constructs a set of fixpoint concept lattices by iteratively expanding the lattices of the initial contexts. To that end, at each iteration a scaling mechanism translates the inter-object links into relational attributes that reflect the available conceptual structures. The output of a RCA task has so far only been described operationally. We propose here an analytic characterization thereof, i.e., a completeness and consistence result connecting fixpoint extents to particular relational structures in the input data.
icfca13-multifca.pdf (910.83 Ko) Télécharger le fichier
lirmm-00833506 , version 1 (21-10-2018)
Amine Mohamed Rouane Hacene, Marianne Huchard, Amedeo Napoli, Petko Valtchev. Soundness and Completeness of Relational Concept Analysis. ICFCA: International Conference on Formal Concept Analysis, May 2013, Dresden, Germany. pp.228-243, ⟨10.1007/978-3-642-38317-5_15⟩. ⟨lirmm-00833506⟩
373 Consultations
248 Téléchargements
