Argumentation for conflicting viewpoint relational database querying - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2013
Within the framework of the European project EcoBioCap, we model a real world use case aiming at conceiving the next generation of food packagings. The objective is to select packaging materials according to possibly con icting requirements expressed by the involved parties (food and packaging industries, health authorities, consumers, waste management authority, etc.). The requirements and user preferences are modeled by several ontological rules provided by the stake- holders expressing their viewpoints and expertise. Since several aspects need to be considered (CO2 and O2 permeance, interaction with the product, sanitary, cost, end of life, etc.) in order to select objects, an argumentation process can be used to express/reason about different aspects or criteria describing the packagings. We define then in this report an argumentation approach which combines a description logic (DLR-Lite) within ASPIC framework for relational database querying. The argumentation step is nally used to express and/or enrich a bipolar query employed for packaging selection.
technical-report-IPMU.pdf (596.5 Ko) Télécharger le fichier
lirmm-00915967 , version 1 (09-12-2013)
  • HAL Id : lirmm-00915967 , version 1
  • PRODINRA : 314873
Nouredine Tamani, Madalina Croitoru. Argumentation for conflicting viewpoint relational database querying. RR-13037, 2013. ⟨lirmm-00915967⟩
282 Consultations
1269 Téléchargements
