Aggregation Semantics for Link Validity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Léa Guizol
  • Fonction : Auteur
  • PersonId : 915140
Madalina Croitoru
Michel Leclère
In this paper we address the problem of link repair in bibliographic knowledge bases. In the context of the SudocAD project, a decision support system (DSS) is being developed, aiming to assist librarians when adding new bibliographic records. The DSS makes the assumption that existing data in the system contains no linkage errors. We lift this assumption and detail a method that allows for link validation. Our method is based on two partitioning semantics which are formally introduced and evaluated on a sample of real data.
AggregationSemanticsforLinkValidity-art-2013.pdf (126.44 Ko) Télécharger le fichier
lirmm-00921018 , version 1 (24-01-2014)
Léa Guizol, Madalina Croitoru, Michel Leclère. Aggregation Semantics for Link Validity. AI: Artificial Intelligence, Dec 2013, Cambridge, United Kingdom. pp.359-372, ⟨10.1007/978-3-319-02621-3_27⟩. ⟨lirmm-00921018⟩
130 Consultations
365 Téléchargements
