Kiabora: An Analyzer of Existential Rule Bases - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Michel Leclère
Swan Rocher
  • Function : Author
  • PersonId : 951324
Kiabora is a software tool dedicated to the analysis of a base of existential rules (also called Datalog± rules). It is able to check if a set of rules belongs to a known class for which entailment is decidable, either directly, by checking some syntactic properties, or by means of its Graph of Rule Dependencies, which allows to combine decidable cases. Kiabora is available online via a simple web form. It is written in Java and is easily extensible to take new decidability results into account. It comes with a textual format, called DLGP (for Datalog Plus), which can be seen as an extension to usual plain Datalog format. In this paper, we briefly introduce the existential rule framework as well as decidability results and presents the analysis performed by Kiabora. More details are available on Kiabora website.
Keywords
Dates and versions
lirmm-00934018 , version 1 (21-01-2014)
Identifiers
Cite
Michel Leclère, Marie-Laure Mugnier, Swan Rocher. Kiabora: An Analyzer of Existential Rule Bases. RR: Web Reasoning and Rule Systems, Jul 2013, Mannheim, Germany. pp.241-246, ⟨10.1007/978-3-642-39666-3_22⟩. ⟨lirmm-00934018⟩
137 View
0 Download
Share
