Aggregation Semantics for Link Validity: Technical Report - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2013
Léa Guizol
  • Fonction : Auteur
  • PersonId : 915140
Madalina Croitoru
Michel Leclère
This paper is about partitioning a set of objects with respect to non-numerical criteria. We represent the partitioning problem as a complete graph partitioning. Two partitioning semantics (global and local partitioning semantics), based on non-numerical criteria, are presented. Partitioning problem algorithms for finding all best partition values are detailed for both semantics.
AggregationSemanticsforLinkValidity-RR.pdf (126.21 Ko) Télécharger le fichier
lirmm-00936246 , version 1 (24-01-2014)
  • HAL Id : lirmm-00936246 , version 1
Léa Guizol, Madalina Croitoru, Michel Leclère. Aggregation Semantics for Link Validity: Technical Report. RR-14003, 2013. ⟨lirmm-00936246⟩
223 Consultations
558 Téléchargements
