Implantation de structures de données compactes pour les triangulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2008
Implementation of compact data structures for triangulations.
Modeling geometric ob jects is inescapable in various domains and applications. The development of acquisition and storage tools has produced a huge increase of the volumes used to store these ob jects. Many disciplines aim to reduce the size of these volumes ; such as compression, which tries to compress the volume, and the elaboration of theoretical compact data structures that minimize the space required for the representation. The goal of this thesis is to design, and evaluate practical and workable solutions for compact representations of triangulations. To do this, two issues has to be explored : modify the internal memory representation of the geometric ob jects, and redefine the abstract types associated to the geometric ob jects. The first solution proposed uses indices of an arbitrary length, instead of absolute references. The gain depends on the size of the triangulation, and the length of the memory word too. The main disadvantage of this solution is the high cost in terms of running time. The second solution uses stable catalogs. The structure gathers triangles into packages, and represents the triangulation as a decomposition of such packages. The number of multiple references to the vertices, and the number of reciprocal references between neighbors are clearly reduced. The results are interesting, and the running time is not dramatically affected by the added indirection levels. The third solution decomposes the triangulation into many sub-triangulations. The references in a sub-triangulation are coded using a reduced number of bits in comparison with the absolute references. The results of this technique are promising, and could be improved using other methods such as the relative coding of references, and sharing common vertex data between different sub-triangulations. The elaboration of compact data structures needs more attention, and several issues have to be explored in order to improve the solutions proposed.
La modélisation des objets géométriques est incontournable dans de nombreuses disciplines et applications. L'évolution des moyens l'acquisition et de stockage a produit une hausse énorme des volumes utilisés pour stocker ces objets. La réduction des tailles de ces volumes fait l'objet de plusieurs domaines de recherches ; comme la compression, qui vise à compresser le volume au maximum, et l'élaboration de structures théoriques compactes qui minimisent la taille nécessaire à la représentation. Le but de cette thèse est de concevoir, et d'évaluer des solutions pratiques et exploitables pour représenter de
façon compacte les triangulations. Pour ce faire, deux issues sont explorées : modifier la représentation interne en mémoire des objets géométriques, et redéfinir les types abstraits des objets géométriques correspondants. Une première solution consiste à utiliser des indices sur une taille arbitraire de bits, au lieu des références absolues. Les gains dépendent de la taille de la triangulation, et aussi de la taille du mot mémoire de la machine. Le handicap majeur est le coût élevé de la méthode en termes de temps d'exécution. Une deuxième piste consiste à utiliser des catalogues stables. L'idée consiste à regrouper les triangles dans des micro-triangulations, et de représenter la triangulation comme un ensemble de ces micro-triangulations. Le nombre des références multiples vers les sommets, et des références réciproques entre voisins est alors nettement réduit. Les résultats sont
prometteurs, sachant que le temps d'exécution n'est pas dramatiquement altéré par la modification des méthodes d'accés aux triangles. Une troisième solution consiste à décomposer la triangulation en plusieurs sous-triangulations permettant ainsi de coder les références dans une sous-triangulation sur un nombre réduit de bits par rapport aux références absolues. Les résultats de cette techniques sont encourageants, et peuvent être amplifiés par d'autres techniques comme le codage relatif des références, ou le partage de l'information géométrique des sommets sur les bords entre les différentes sous-triangulations. L'élaboration de structures compactes nécessite encore plus d'intérêts, et plusieurs pistes sont à explorer pour pouvoir arriver à des solutions plus économiques en termes d'espace mémoire.
these-abdelkrim.pdf (12.45 Mo) Télécharger le fichier
tel-00336178 , version 1 (03-11-2008)
  • HAL Id : tel-00336178 , version 1
Abdelkrim Mebarki. Implantation de structures de données compactes pour les triangulations. Informatique [cs]. Université Nice Sophia Antipolis, 2008. Français. ⟨NNT : ⟩. ⟨tel-00336178⟩
Collections
INRIA INRIA2
325 Consultations
790 Téléchargements
