Supervision des réseaux pair à pair structurés appliquée à la sécurité des contenus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Monitoring of structured peer-to-peer networks applied to the security of contents
The purpose of this thesis is to design and implement new monitoring solutions which are able to deal with the security issues affecting data stored in large structured P2P networks (DHT). There are two major types of issues. First, P2P networks are used to spread illegal contents whose activity is difficult to monitor accurately. Second, the indexation of regular contents can be corrupted (Sybil attack). We first designed a new approach to monitor contents based on the insertion of distributed probes in the network to take control of the indexation mechanism. The probes can attract all the related requests for a given content and assess the peers intent to access it by generating very attractive honeypots. We describe the weaknesses of the network allowing our solution to be effective despite recent protection mechanisms. We then present the services offered by our monitoring architecture and we evaluate its efficiency on KAD. We also present a real deployment whose purpose is to study pedophile contents on this network. Then, we focus on data integrity in distributed hash tables. We performed large scale monitoring campaigns on the KAD network. Our observations show that it suffers from a very harmful pollution of its indexation mechanism affecting 2/3 of the shared files and also from a large number of localized attacks targeting contents. To mitigate these threats, we propose an efficient way to detect attacks by analysing the distribution of the peers' ID found around an entry after a DHT lookup and a counter-measure which can protect the peers at a negligible cost. Finally, we evaluate our solution in real P2P networks.
L'objectif de cette thèse est de concevoir et d'appliquer de nouvelles méthodes de supervision capables d'appréhender les problèmes de sécurité affectant les données au sein des réseaux P2P structurés (DHT). Ceux-ci sont de deux types. D'une part les réseaux P2P sont utilisés pour diffuser des contenus illégaux dont l'activité est difficile à superviser. D'autre part, l'indexation des contenus légitimes peut être corrompue (attaque Sybil). Nous proposons tout d'abord une méthode de supervision des contenus basée sur l'insertion de sondes et le contrôle du mécanisme d'indexation du réseau. Celle-ci permet d'attirer l'ensemble des requêtes des pairs pour un contenu donné, puis de vérifier leur intention en générant des appâts très attractifs. Nous décrivons ainsi les faiblesses du réseau permettant la mise en œuvre de notre méthode en dépit des protections existantes. Nous présentons les fonctionnalités de notre architecture et en évaluons l'efficacité sur le réseau P2P KAD avant de présenter un déploiement réel ayant pour but l'étude des contenus pédophiles. Nous considérons ensuite la sécurité des données indexées dans une DHT. Nous supervisons le réseau KAD et montrons que celui-ci est victime d'une pollution particulièrement néfaste affectant 2/3 des fichiers mais aussi de nombreuses attaques ciblées affectant la sécurité des contenus stockés. Nous proposons un moyen de détecter efficacement cette dernière attaque en analysant la distribution des identifiants des pairs autour d'une référence ainsi qu'une contre-mesure permettant de protéger les pairs à un coût négligeable. Nous terminons par l'évaluation de la protection au sein de réseaux P2P réels.
manuscrit_these_cholez.pdf (6.14 Mo) Télécharger le fichier
presentation_these_cholez.pdf (1.13 Mo) Télécharger le fichier
Format : Autre
tel-00608907 , version 1 (15-07-2011)
  • HAL Id : tel-00608907 , version 1
Thibault Cholez. Supervision des réseaux pair à pair structurés appliquée à la sécurité des contenus. Réseaux et télécommunications [cs.NI]. Université Henri Poincaré - Nancy I, 2011. Français. ⟨NNT : ⟩. ⟨tel-00608907⟩
776 Consultations
1068 Téléchargements
