Partitioning XML data, towards distributed and parallel management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Méthode de Partitionnement pour le traitement distribué et parallèle de données XML.
With the widespread diffusion of XML as a format for representing data generated and exchanged over the Web, main query and update engines have been designed and implemented in the last decade. A kind of engines that are playing a crucial role in many applications are « main-memory » systems, which distinguish for the fact that they are easy to manage and to integrate in a programming environment. On the other hand, main-memory systems have scalability issues, as they load the entire document in main-memory before processing. This Thesis presents an XML partitioning technique that allows main-memory engines to process a class of XQuery expressions (queries and updates), that we dub « iterative », on arbitrarily large input documents. We provide a static analysis technique to recognize these expressions. The static analysis is based on paths extracted from the expression and does not need additional schema information. We provide algorithms using path information for partitioning the input documents, so that the query or update can be separately evaluated on each part in order to compute the final result. These algorithms admit a streaming implementation, whose effectiveness is experimentally validated. Besides enabling scalability, our approach is also characterized by the fact that it is easily implementable into a MapReduce framework, thus enabling parallel query/update evaluation on the partitioned data.
Durant cette dernière décennie, la diffusion du format XML pour représenter les données générées par et échangées sur le Web a été accompagnée par la mise en œuvre de nombreux moteurs d’évaluation de requêtes et de mises à jour XQuery. Parmi ces moteurs, les systèmes « mémoire centrale » (Main-memory Systems) jouent un rôle très important dans de nombreuses applications. La gestion et l’intégration de ces systèmes dans des environnements de programmation sont très faciles. Cependant, ces systèmes ont des problèmes de passage à l’échelle puisqu’ils requièrent le chargement complet des documents en mémoire centrale avant traitement.Cette thèse présente une technique de partitionnement des documents XML qui permet aux moteurs « mémoire principale » d’évaluer des expressions XQuery (requêtes et mises à jour) pour des documents de très grandes tailles. Cette méthode de partitionnement s’applique à une classe de requêtes et mises à jour pertinentes et fréquentes, dites requêtes et mises à jour itératives.Cette thèse propose une technique d'analyse statique pour reconnaître les expressions « itératives ». Cette analyse statique est basée sur l’extraction de chemins à partir de l'expression XQuery, sans utilisation d'information supplémentaire sur le schéma. Des algorithmes sont spécifiés, utilisant les chemins extraits par l’étape précédente, pour partitionner les documents en entrée en plusieurs parties, de sorte que la requête ou la mise à jour peut être évaluée sur chaque partie séparément afin de calculer le résultat final par simple concaténation des résultats obtenus pour chaque partie. Ces algorithmes sont mis en œuvre en « streaming » et leur efficacité est validée expérimentalement.En plus, cette méthode de partitionnement est caractérisée également par le fait qu'elle peut être facilement implémentée en utilisant le paradigme MapReduce, permettant ainsi d'évaluer une requête ou une mise à jour en parallèle sur les données partitionnées.
VD2_MALLA_NOOR_21092012.pdf (1.87 Mo) Télécharger le fichier
tel-00759173 , version 2 (31-10-2012)
tel-00759173 , version 1 (30-11-2012)
tel-00759173 , version 3 (08-12-2015)
  • HAL Id : tel-00759173 , version 3
Noor Malla. Partitioning XML data, towards distributed and parallel management. Other [cs.OH]. Université Paris Sud - Paris XI, 2012. English. ⟨NNT : 2012PA112154⟩. ⟨tel-00759173v3⟩
360 Consultations
314 Téléchargements
