Mathematical modeling of T CD8 immune response dynamics, at cellular and molecualr scales
Modélisation mathématique des dynamiques de la réponse immunitaire T CD8, aux échelles cellulaire et moléculaire
Immune response occurs when a pathogen enters the organism and launches an infection. Herewe focused on a specific cell population which takes part in the response : the CD8 T lymphocytes.We first developed an nonlinear age-structured model which accounts for the dynamics of theimmune response at a cell scale. We studied mathematically the existence and stability of steadystates. Hence, we got some properties which highlighted, under certain conditions, some long termdynamics corresponding to biologically expected situation.We then led a systematic estimation of parameter values in the model, in order to find a setof values for each parameter which enabled us to correctly reproduce experimental data. Thanksto this work, we got information of the influence of each parameter in the model and informationof their variations depending on the nature of the pathogen.Eventually, we considered dynamics of the immune response at a molecular scale. We createda network of signal key events, starting from cell activation due to an antigen encounter, to cellcycle entry or apoptosis of the cell. We thus elaborated a sub-model focused on the choice betweensurvival or apoptosis, that we mathematically and numerically studied. Thanks to this model, westudied concentration dynamics of the proteins involved in intracellular signaling in CD8 T cellresponse.
La réponse immunitaire se produit en réaction à une infection, c’est-à-dire à l’introduction d’un pathogène dans l’organisme. Nous nous intéressons à une population de cellules spécifique de la réponse, les lymphocytes T CD8. Nous avons développé un modèle non linéaire structuré en âgedes dynamiques de cette réponse, à l’échelle cellulaire. Nous avons étudié l’existence et la stabilité des états d’équilibre, et obtenu des propriétés mettant en évidence, sous certaines conditions, des dynamiques à long terme correspondant à la situation biologiquement attendue. Nous avons ensuite réalisé une estimation systématique des valeurs de paramètres du modèle, afin de déterminer un ensemble de valeurs pour chaque paramètre qui permet de reproduire convenablement des données expérimentales. Cette démarche permet d’obtenir des informations sur l’influence des paramètres dans le modèle, et sur leurs variations selon la nature du pathogène.Enfin, nous nous sommes intéressés aux dynamiques de la réponse à l’échelle moléculaire, en écrivant un réseau des évènements de signalisation clès depuis l’activation de la cellule en présence d’un antigène, jusqu’à l’entrée en cycle ou l’apoptose de la cellule. Nous avons déterminé un sous modèle centré sur les choix entre survie et apoptose, que nous avons étudié mathématiquement et numériquement. Ce modèle a permis d’étudier les dynamiques de concentrations des protéines impliquées dans la signalisation intra-cellulaire de la réponse T CD8.
