A high-order Discontinuous Galerkin discretization for solving two-dimensional Lagrangian hydrodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Utilisation des méthodes Galerkin discontinues pour la résolution de l'hydrodynamique Lagrangienne bi-dimensionnelle
The intent of the present work was the development of a high-order discontinuous Galerkin scheme for solving the gas dynamics equations written under total Lagrangian form on two-dimensional unstructured grids. To achieve this goal, a progressive approach has been used to study the inherent numerical difficulties step by step. Thus, discontinuous Galerkin schemes up to the third order of accuracy have firstly been implemented for the one-dimensional and two-dimensional scalar conservation laws on unstructured grids. The main feature of the presented DG scheme lies on the use of a polynomial Taylor basis. This particular choice allows in the two-dimensional case to take into general unstructured grids account in a unified framework. In this frame, a vertex-based hierarchical limitation which preserves smooth extrema has been implemented. A generic form of numerical fluxes ensuring the global stability of our semi-discrete discretization in the $L_2$ norm has also been designed. Then, this DG discretization has been applied to the one-dimensional system of conservation laws such as the acoustic system, the shallow-water one and the gas dynamics equations system written in the Lagrangian form. Noticing that the application of the limiting procedure, developed for scalar equations, to the physical variables leads to spurious oscillations, we have described a limiting procedure based on the characteristic variables. In the case of the one-dimensional gas dynamics case, numerical fluxes have been designed so that our semi-discrete DG scheme satisfies a global entropy inequality. Finally, we have applied all the knowledge gathered to the case of the two-dimensional gas dynamics equation written under total Lagrangian form. In this framework, the computational grid is fixed, however one has to follow the time evolution of the Jacobian matrix associated to the Lagrange-Euler flow map, namely the gradient deformation tensor. In the present work, the flow map is discretized by means of continuous mapping, using a finite element basis. This provides an approximation of the deformation gradient tensor which satisfies the important Piola identity. The discretization of the physical conservation laws for specific volume, momentum and total energy relies on a discontinuous Galerkin method. The scheme is built to satisfying exactly the Geometric Conservation Law (GCL). In the case of the third-order scheme, the velocity field being quadratic we allow the geometry to curve. To do so, a Bezier representation is employed to define the mesh edges. We illustrate the robustness and the accuracy of the implemented schemes using several relevant test cases and performing rate convergences analysis.
Le travail présenté ici avait pour but le développement d'un schéma de type Galerkin discontinu (GD) d'ordre élevé pour la résolution des équations de la dynamique des gaz écrites dans un formalisme Lagrangien total, sur des maillages bi-dimensionnels totalement déstructurés. A cette fin, une méthode progressive a été utilisée afin d'étudier étape par étape les difficultés numériques inhérentes à la discrétisation Galerkin discontinue ainsi qu'aux équations de la dynamique des gaz Lagrangienne. Par conséquent, nous avons développé dans un premier temps des schémas de type Galerkin discontinu jusqu'à l'ordre trois pour la résolution des lois de conservation scalaires mono-dimensionnelles et bi-dimensionnelles sur des maillages déstructurés. La particularité principale de la discrétisation GD présentée est l'utilisation des bases polynomiales de Taylor. Ces dernières permettent, dans le cadre de maillages bi-dimensionnels déstructurés, une prise en compte globale et unifiée des différentes géométries. Une procédure de limitation hiérarchique, basée aux noeuds et préservant les extrema réguliers a été mise en place, ainsi qu'une forme générale des flux numériques assurant une stabilité globale L2 de la solution. Ensuite, nous avons tâché d'appliquer la discrétisation Galerkin discontinue développée aux systèmes mono-dimensionnels de lois de conservation comme celui de l'acoustique, de Saint-Venant et de la dynamique des gaz Lagrangienne. Nous avons noté au cours de cette étude que l'application directe de la limitation mise en place dans le cadre des lois de conservation scalaires, aux variables physiques des systèmes mono-dimensionnels étudiés provoquait l'apparition d'oscillations parasites. En conséquence, une procédure de limitation basée sur les variables caractéristiques a été développée. Dans le cas de la dynamique des gaz, les flux numériques ont été construits afin que le système satisfasse une inégalité entropique globale. Fort de l'expérience acquise, nous avons appliqué la discrétisation GD mise en place aux équations bi-dimensionnelles de la dynamique des gaz, écrites dans un formalisme Lagrangien total. Dans ce cadre, le domaine de référence est fixe. Cependant, il est nécessaire de suivre l'évolution temporelle de la matrice jacobienne associée à la transformation Lagrange-Euler de l'écoulement, à savoir le tenseur gradient de déformation. Dans le travail présent, la transformation résultant de l'écoulement est discrétisée de manière continue à l'aide d'une base Éléments Finis. Cela permet une approximation du tenseur gradient de déformation vérifiant l'identité essentielle de Piola. La discrétisation des lois de conservation physiques sur le volume spécifique, le moment et l'énergie totale repose sur une méthode Galerkin discontinu. Le schéma est construit de sorte à satisfaire de manière exacte la loi de conservation géométrique (GCL). Dans le cas du schéma d'ordre trois, le champ de vitesse étant quadratique, la géométrie doit pouvoir se courber. Pour ce faire, des courbes de Bézier sont utilisées pour la paramétrisation des bords des cellules du maillage. Nous illustrons la robustesse et la précision des schémas mis en place à l'aide d'un grand nombre de cas tests pertinents, ainsi que par une étude de taux de convergence.
these_fv.pdf (7.22 Mo) Télécharger le fichier
tel-00765575 , version 1 (14-12-2012)
  • HAL Id : tel-00765575 , version 1
François Vilar. A high-order Discontinuous Galerkin discretization for solving two-dimensional Lagrangian hydrodynamics. Numerical Analysis [math.NA]. Université Sciences et Technologies - Bordeaux I, 2012. English. ⟨NNT : ⟩. ⟨tel-00765575⟩
359 Consultations
496 Téléchargements
