Méthode de type Galerkin discontinu en maillages multi-éléments (et non-conformes) pour la résolution numérique des équations de Maxwell instationnaires - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
High order non-conforming multi-element discontinuous Galerkin method for time-domain electromagnetics
This thesis is concerned with the study of a Discontinuous Galerkin Time-Domain method (DGTD), for the numerical resolution of the unsteady Maxwell equations on hybrid tetrahedral/hexahedral in 3D (triangular/quadrangular in 2D) and non-conforming meshes, denoted by DGTD-PpQk method. Like in several studies on various hybrid time domain methods (such as a combination of Finite Volume with Finite Difference methods, or Finite Element with Finite Difference, etc.), our general objective is to mesh objects with complex geometry by tetrahedra for high precision and mesh the surrounding space by square elements for simplicity and speed. In the discretization scheme of the DGTD method considered here, the electromagnetic field components are approximated by a high order nodal polynomial, using a centered approximation for the surface integrals. Time integration of the associated semi-discrete equations is achieved by a second or fourth order Leap-Frog scheme. After introducing the historical and physical context of Maxwell equations, we present the details of the DGTD-PpQk method. We prove the L2 stability of this method by establishing the conservation of a discrete analog of the eletromagnetic energy and a sufficient CFL-like stability condition is exhibited. The theoritical convergence of the scheme is also studied, this leads to a-priori error estimate that takes into account the hybrid nature of the mesh. Afterward, we perform a complete numerical study in 2D (TMz waves), for several test problems, on hybrid and non-conforming meshes, and for homogeneous or heterogeneous media. We do the same for the 3D implementation, with more realistic simulations, for example the propagation in a heterogeneous human head model. We show the consistency between the mathematical and numerical results of this DGTD-PpQk method, and its contribution in terms of accuracy and CPU time.
Cette thèse porte sur l'étude d'une méthode de type Galerkin discontinu en domaine temporel (GDDT), afin de résoudre numériquement les équations de Maxwell instationnaires sur des maillages hybrides tétraédriques/hexaédriques en 3D (triangulaires/quadrangulaires en 2D) et non-conformes, que l'on note méthode GDDT-PpQk. Comme dans différents travaux déjà réalisés sur plusieurs méthodes hybrides (par exemple des combinaisons entre des méthodes Volumes Finis et Différences Finies, Éléments Finis et Différences Finies, etc.), notre objectif principal est de mailler des objets ayant une géométrie complexe à l'aide de tétraèdres, pour obtenir une précision optimale, et de mailler le reste du domaine (le vide environnant) à l'aide d'hexaèdres impliquant un gain en terme de mémoire et de temps de calcul. Dans la méthode GDDT considérée, nous utilisons des schémas de discrétisation spatiale basés sur une interpolation polynomiale nodale, d'ordre arbitraire, pour approximer le champ électromagnétique. Nous utilisons un flux centré pour approcher les intégrales de surface et un schéma d'intégration en temps de type saute-mouton d'ordre deux ou d'ordre quatre. Après avoir introduit le contexte historique et physique des équations de Maxwell, nous présentons les étapes détaillées de la méthode GDDT-PpQk. Nous réalisons ensuite une analyse de stabilité L2 théorique, en montrant que cette méthode conserve une énergie discrète et en exhibant une condition suffisante de stabilité de type CFL sur le pas de temps, ainsi que l'analyse de convergence en h (théorique également), conduisant à un estimateur d'erreur a-priori. Ensuite, nous menons une étude numérique complète en 2D (ondes TMz), pour différents cas tests, des maillages hybrides et non-conformes, et pour des milieux de propagation homogènes ou hétérogènes. Nous faisons enfin de même pour la mise en oeuvre en 3D, avec des simulations réalistes, comme par exemple la propagation d'une onde électromagnétique dans un modèle hétérogène de tête humaine. Nous montrons alors la cohérence entre les résultats mathématiques et numériques de cette méthode GDDT-PpQk, ainsi que ses apports en termes de précision et de temps de calcul.
Durochat-These_vfinale.pdf (23.68 Mo) Télécharger le fichier
Durochat-Soutenance.pdf (14.34 Mo) Télécharger le fichier
Format : Autre
tel-00805935 , version 1 (02-04-2013)
  • HAL Id : tel-00805935 , version 1
Clément Durochat. Méthode de type Galerkin discontinu en maillages multi-éléments (et non-conformes) pour la résolution numérique des équations de Maxwell instationnaires. Equations aux dérivées partielles [math.AP]. Université Nice Sophia Antipolis, 2013. Français. ⟨NNT : ⟩. ⟨tel-00805935⟩
619 Consultations
1496 Téléchargements
