Étude de modèles épidémiologiques : Stabilité, observation et estimation de paramètres - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Study of epidemic models: stability, observation and parameter estimation
The purpose of this thesis is on the one hand to study stability of equilibria of some epidemic models and secondly to construct an observer to estimate the non-measured states and a key parameter in a within host model. We propose extensions of classical models SIR, SIRS and SIS and we study the global stability of their equilibria. In presence of multiple pathogen strains, we proved that competitive exclusion principle holds: the strain having the largest threshold wins the competition by eliminating the others. It turns out that the winning strain is the one for which the equilibrium gives the minimum of the susceptible host population. This can be interpreted as pessimization principle. By considering the same model with two strains and a frequency-dependent type of the contact law, we prove that dynamics changes and a coexistence equilibrium exists and it is globally asymptotically stable under some conditions. The asymptotic behavior of the two other boundary equilibria is also established. The stability study of equilibrium states is mainly done by construction of Lyapunov functions combined with LaSalle's invariance principle. We consider an age-structured within-host model of the \textit{Plasmodium falciuparum} parasite with a general infection force. We develop a method to estimate the total parasite burden that cannot be measured by the current methods. To this end, we use some tools from control theory, more precisely observers with unknown inputs, to estimate the non measured states from the measured ones (data). From this, we deduce a method to estimate an unknown parameter that represents infection rate of healthy reed blood cells by the parasites.
L'objectif de cette thèse est d'une part l'étude de la stabilité des équilibres de certains modèles épidémiologiques et d'autre part la construction d'un observateur pour l'estimation des états non mesurés et d'un paramètre clé pour un modèle intra-hôte. Nous proposons des extensions des modèles du type SIR, SIRS et SIS et nous étudions la stabilité globales de leur équilibres. En présence de plusieurs souches de pathogène d'un modèle SIS, on montre que le principe de compétition exclusive est vérifié: la souche qui maximise un seuil remporte la compétition en éliminant les autres souches. Il se trouve aussi que la souche gagnante est celle qui donne à l'équilibre le minimum de population hôte susceptible. Ceci peut-être interprété comme étant un principe de pessimisation. En considérant ce modèle avec cette fois une loi de contact de type fréquence-dépendante, on montre que la dynamique change et qu'un équilibre de coexistence existe et qui est globalement asymptotiquement stable sous certaines conditions. Le comportement asymptotique des deux équilibres frontières est aussi prouvée. L'étude de la stabilité des états d'équilibres est essentiellement faite par la construction des fonctions de Lyapunov combiné avec le principe d'invariance de LaSalle. On considère un modèle intra-hôte structuré en classe d'âge du parasite Plasmodium falciparum avec une force d'infection général. Nous développons une méthode d'estimation de la charge parasitaire totale dont on ne sait mesurée par les méthodes actuellement connues. Pour cela nous utilisons les outils de la théorie du contrôle, plus particulièrement les observateurs à entrées inconnues, pour estimer les états non mesurés à partir des états mesurés (données). De cela nous déduisons une méthode d'estimation d'un paramètre inconnu qui représente le taux d'infection des globules rouges saines par les parasites.
BicharaPhDThesis.pdf (6.93 Mo) Télécharger le fichier
tel-01749335 , version 2 (08-07-2013)
tel-01749335 , version 1 (29-03-2018)
  • HAL Id : tel-01749335 , version 2
Derdei Bichara. Étude de modèles épidémiologiques : Stabilité, observation et estimation de paramètres. Systèmes dynamiques [math.DS]. Université de Lorraine, 2013. Français. ⟨NNT : 2013LORR0011⟩. ⟨tel-01749335v2⟩
1637 Consultations
14455 Téléchargements
