Recursive estimation for some deformation models
Estimation récursive dans certains modèles de déformation
This thesis is devoted to the study of some semi-parametric deformation models.Our aim is to provide recursive methods, related to stochastic algorithms, in order to estimate the different parameters of the models. In the first part, we present the theoretical tools which we will use in the next part. On the one hand, we focus on stochastic approximation methods, in particular the Robbins-Monro algorithm and the Kiefer-Wolfowitz algorithm. On the other hand, we introduce kernel estimators in order to estimate a probability density function and a regression function. More particularly, we present the two most famous kernel estimators which are the one of Parzen-Rosenblatt and the one of Nadaraya-Watson. We also present their recursive version.In the second part, we present the results we obtained in this thesis.Firstly, we provide a recursive estimation method of the shift parameter and the regression function for the translation model in which the regression function is periodic. Secondly, we extend this estimation procedure to the shape invariant model, providing estimation of the height parameter, the translation parameter and the scale parameter, as well as the common shape function.Thirdly, we are interested in the parametric deformation model of random variables where the deformation is known and depending on an unknown parameter.For these three models, we establish the almost sure convergence and the asymptotic normality of each estimator. Finally, we numerically illustrate the asymptotic behaviour of our estimators on simulated data and on real data.
Cette thèse est consacrée à l'étude de certains modèles de déformation semi-paramétriques. Notre objectif est de proposer des méthodes récursives, issues d'algorithmes stochastiques, pour estimer les paramètres de ces modèles. Dans la première partie, on présente les outils théoriques existants qui nous seront utiles dans la deuxième partie. Dans un premier temps, on présente un panorama général sur les méthodes d'approximation stochastique, en se focalisant en particulier sur les algorithmes de Robbins-Monro et de Kiefer-Wolfowitz. Dans un second temps, on présente les méthodes à noyaux pour l'estimation de fonction de densité ou de régression. On s'intéresse plus particulièrement aux deux estimateurs à noyaux les plus courants qui sont l'estimateur de Parzen-Rosenblatt et l'estimateur de Nadaraya-Watson, en présentant les versions récursives de ces deux estimateurs.Dans la seconde partie, on présente tout d'abord une procédure d'estimation récursive semi-paramétrique du paramètre de translation et de la fonction de régression pour le modèle de translation dans la situation où la fonction de lien est périodique. On généralise ensuite ces techniques au modèle vectoriel de déformation à forme commune en estimant les paramètres de moyenne, de translation et d'échelle, ainsi que la fonction de régression. On s'intéresse finalement au modèle de déformation paramétrique de variables aléatoires dans le cadre où la déformation est connue à un paramètre réel près. Pour ces trois modèles, on établit la convergence presque sûre ainsi que la normalité asymptotique des estimateurs paramétriques et non paramétriques proposés. Enfin, on illustre numériquement le comportement de nos estimateurs sur des données simulées et des données réelles.
Origin : Version validated by the jury (STAR)
