Graph- based segmentation of skeletal striated muscles in NMR images
De la segmentation au moyen de graphes d’images de muscles striés squelettiques acquises par RMN
Segmentation of magnetic resonance images (MRI) of skeletal striated muscles is of crucial interest when studying myopathies. Diseases understanding, therapeutic followups of patients, etc. rely on discriminating the muscles in MRI anatomical images. However, delineating the muscle contours manually is an extremely long and tedious task, and thus often a bottleneck in clinical research. Typical automatic segmentation methods rely on finding discriminative visual properties between objects of interest, accurate contour detection or clinically interesting anatomical points. Skeletal muscles show none of these features in MRI, making automatic segmentation a challenging problem. In spite of recent advances on segmentation methods, their application in clinical settings is difficult, and most of the times, manual segmentation and correction is still the only option. In this thesis, we propose several approaches for segmenting skeletal muscles automatically in MRI, all related to the popular graph-based Random Walker (RW) segmentation algorithm. The strength of the RW method relies on its robustness in the case of weak contours and its fast and global optimization. Originally, the RW algorithm was developed for interactive segmentation: the user had to pre-segment small regions of the image – called seeds – before running the algorithm which would then complete the segmentation. Our first contribution is a method for automatically generating and labeling all the appropriate seeds, based on a Markov Random Fields formulation integrating prior knowledge of the relative positions, and prior detection of contours between pairs of seeds. A second contribution amounts to incorporating prior knowledge of the shape directly into the RW framework. Such formulation retains the probabilistic interpretation of the RW algorithm and thus allows to compute the segmentation by solving a large but simple sparse linear system, like in the original method. In a third contribution, we propose to develop a learning framework to estimate the optimal set of parameters for balancing the contrast term of the RW algorithm and the different existing prior models. The main challenge we face is that the training samples are not fully supervised. Specifically, they provide a hard segmentation of the medical images, instead of the optimal probabilistic segmentation, which corresponds to the desired output of the RW algorithm. We overcome this challenge by treating the optimal probabilistic segmentation as a latent variable. This allows us to employ the latent Support Vector Machine (latent SVM) formulation for parameter estimation. All proposed methods are tested and validated on real clinical datasets of MRI volumes of lower limbs.
La segmentation d’images anatomiques de muscles striés squelettiques acquises par résonance magnétique nucléaire (IRM) présente un grand intérêt pour l’étude des myopathies. Elle est souvent un préalable nécessaire pour l’étude les mécanismes d’une maladie, ou pour le suivi thérapeutique des patients. Cependant, le détourage manuel des muscles est un travail long et fastidieux, au point de freiner les recherches cliniques qui en dépendent. Il est donc nécessaire d’automatiser cette étape. Les méthodes de segmentation automatique se basent en général sur les différences d’aspect visuel des objets à séparer et sur une détection précise des contours ou de points de repère anatomiques pertinents. L’IRM du muscle ne permettant aucune de ces approches, la segmentation automatique représente un défi de taille pour les chercheurs. Dans ce rapport de thèse, nous présentons plusieurs méthodes de segmentation d’images de muscles, toutes en rapport avec l’algorithme dit du marcheur aléatoire (MA). L’algorithme du MA, qui utilise une représentation en graphe de l’image, est connu pour être robuste dans les cas où les contours des objets sont manquants ou incomplets et pour son optimisation numérique rapide et globale. Dans sa version initiale, l’utilisateur doit d’abord segmenter de petites portions de chaque région de l’image, appelées graines, avant de lancer l’algorithme pour compléter la segmentation. Notre première contribution au domaine est un algorithme permettant de générer et d’étiqueter automatiquement toutes les graines nécessaires à la segmentation. Cette approche utilise une formulation en champs aléatoires de Markov, intégrant une connaissance à priori de l’anatomie et une détection préalable des contours entre des paires de graines. Une deuxième contribution vise à incorporer directement la connaissance à priori de la forme des muscles à la méthode du MA. Cette approche conserve l’interprétation probabiliste de l’algorithme original, ce qui permet de générer une segmentation en résolvant numériquement un grand système linéaire creux. Nous proposons comme dernière contribution un cadre d’apprentissage pour l’estimation du jeu de paramètres optimaux régulant l’influence du terme de contraste de l’algorithme du MA ainsi que des différents modèles de connaissance à priori. La principale difficulté est que les données d’apprentissage ne sont pas entièrement supervisées. En effet, l’utilisateur ne peut fournir qu’une segmentation déterministe de l’image, et non une segmentation probabiliste comme en produit l’algorithme du MA. Cela nous amène à faire de la segmentation probabiliste optimale une variable latente, et ainsi à formuler le problème d’estimation sous forme d’une machine à vecteurs de support latents (latent SVM). Toutes les méthodes proposées sont testées et validées sur des volumes de muscles squelettiques acquis par IRM dans un cadre clinique.
Origin : Version validated by the jury (STAR)
